Using PV as a frit on Curved Roof
3 ANTWORTEN 3
Nachricht 1 von 4
mzamzam
573 Aufrufe, 3 Antworten
I currently have a section of my building acting as an overhang, and I put in my trusses and beams in the area I would like to place my PV on my roof. I want to use some sort of glass roof with thin film PV placed in a grid style, where there is a frame around each panel that allows light to shine through the overhang. How could I go about doing something like that? I have attached some pictures for my inspiration, as well as a screenshot of what my roof looks like now (I just have the PV as a material, but obviously no light can shine through). Thanks!
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: mzamzam
I'm not sure what you are asking. Are you wondering how to create a material to assign to the geometry, or how to create the geometry?  Or are you asking about rendering?
Nachricht 3 von 4
mzamzam
als Antwort auf: barthbradley
I want to know if there is a way to create a material that has areas that are transparent for rendering purposes (I want the light to be able to pass through certain areas, and be blocked in others)
Nachricht 4 von 4
I would direct you to PBR Materials.
Start learning here:
https://www.autodesk.com/autodesk-university/class/PBR-Materials-Revit-What-These-Materials-Mean-and...
...that appears to be a bad link now. Start here instead:
https://therevitkid.blogspot.com/2020/04/how-to-use-physically-based-rendering.html
and search here:
https://source.substance3d.com/
