In the image below, the mapping path for keynote text file shows an option for exernal sources and as you can see, it is empty. Is there a way, when using collaboration for Revit, to also host this text file in the cloud project files so that it is accessible to all team members?
Gelöst! Gehe zur Lösung
Gelöst von AdamPeter. Gehe zur Lösung
Greetings and thanks for your post.
The External Resources button is somewhat futuristic in nature as there are not any connections yet outside the Inport/Link RVT dialog.
Excellent. Thank you for the prompt reply. Any rough estimate for the expansion of the utility?
Best,
Barbara
How did that answer qualified as "Solved"?
How do we share Keynote TXT files in C4R (revit 2016)?
Thank you
Regards
Gio
