Using iPad/Viewer to add data to Native Revit model as paraqmeter
AhmadAdawi
AhmadAdawi
Hello!
I want to receive data from other engineers like construction teams and others to reflect these data into Revit model. As we know traditional methods using papers are not efficient and many miss understands may happen.
Other teams are not familiar with Revit and may make wrong change in the native models if they add data using models.
I want to get data from others by allowing them to add the comments,notes or any other data directly using 3D viewer like (Autodesk Design Review, A360, etc) by adding editable parameter, Then these data to be extracted from viewer to Revit model by excel or any other method. (I can link the elements by unique key parameter for each object/elements/room ).
ie, I asked if there any way to add comments to model from site by using iPad/Laptop by add comments directly to object as parameter not using markup shots. this will help us in construction to follow issues by some fillers in Revit.
Please advise if we have this option in viewer Autodesk products
Thanks and best regards,
Ahmad M. Adawi
yurikim
You can consider BIM 360 Docs:
https://info.bim360.autodesk.com/bim-360-docs
Yet I don't think there will be any viewer that allows changes to the Revit models. Instead, in BIM 360 Docs, you can use Markups as well as Issues to manage and collaborate on design changes.
Hope this helps.
Yuri Kim
Product Support Specialist, AEC
AhmadAdawi
Thanks Yuri,
No need to edit parameter in Revit. What I need is to add data to viewer as parameter on the object then export these data to excel with native parameter data.
