I am trying to use the CUT command to created some complex shapes. PS - relatively new to Revit but experienced in Autocad Architecture.
I'm experimenting with families and trying to use extrusions and then cut our other extrusions to mold the shape. I would have thought that cut is like a subtract command of a mass element. The only way I can get it to work is to create the piece I want to subtract -> make it a void -> use the cut. The only problem is that I need to leave the void extrusion there. If it moves it dynamically changes within the base extrusion.
Is this the correct way it operates or I am just not getting it. I've uploaded a test file I've what I mean. I expected to have the slots cut from the base shape and not to have to leave the void extrusions there ??
Thanks to anybody in advance
Gelöst! Gehe zur Lösung
Gelöst von planner_matlabi. Gehe zur Lösung
Hi
For Boolean (Subtract) Two Form in Revit Must Use of Void From
But
if Draw From and after Boolean Two Form , First Must Chang Form Solid To Void and after Use Cut in Modify Tab
If it solves your problem, feel free to click Accept Solution.
I am a teacher
Send Your Email For Me until Send My Traning For You (Free)
Of course, I am an Iranian, and the training is Persian
But I think to help you
Planner_Matlabi@yahoo.com
