Using Adaptive Families in Other Family Types
30 ANTWORTEN 30
Nachricht 1 von 31
rmarkowitz
5326 Aufrufe, 30 Antworten
   I'm wondering if there is a workaround for the problem I am having nesting "Adaptive Families" in Face-Based Families.
   Essentially, I have an adaptive family element in a project I am doing. I also have a series of face-based models. I have come in to a situation where I would like to use the adaptive element as a component of one of the face-based elements, rather than adding the adaptive element on top of the face-based element in the file itself (since I have a lot of identical elements). When I try to load my adaptive family into my face-based family, Revit says I can only import my adaptive family into other adaptive, or mass families.
   Any suggestions on how to work around this so I don't end up placing hundreds of adaptive points in my model would be greatly appreciated.
Thanks!
30 ANTWORTEN 30
Nachricht 2 von 31
RDAOU
als Antwort auf: rmarkowitz
@rmarkowitz Hi
That's an uncommon way to make an AC lose its purpose. I am not at a computer at the moment to simulate something but I can, without second thought say, that's how it is with Adaptive Components. Logically speaking (correct me if I'm wrong); if we assume the nesting the Adaptive Component into a lets say window family is A OK, the Adaptive family won't be adaptive anymore once that end face based family is loaded into the project...so if it's losing it's adaptability why not just model it in the face base family!?
too much time? Well in theory...
1. you can export the adaptive as a SAT (geometry); load it into a generic one; add a couple of parameters to it; then nest it into your face based one...no more adaptives
2. Unless you need that face based family to be face based, work it all out as a Mass family... you can load a generic into a mass family and an adaptive into a mass family so might be one way to have a mediator
  • You want to keep it adaptive and don't want to place them on your own 100 times? Let Dynamo do it for you...or a draftsman :leicht_lächelndes_Gesicht:
One can always be creative and come up with something...But again one still have to see what you have before one may judge what is best
Nachricht 3 von 31
rmarkowitz
Hi @RDAOU
You make some good points. I can give you a few more specifics to explain what I'm trying to achieve:
   Imagine you have some LED tape. This is an adaptive component so that it can be attached to a variety of surfaces (round walls, straight walls, other geometry). Now you have a sign that is a face based family so that it hosts to walls.
   Now you want to put the LED tape in the signs. You still need it to be the same type that's in the main file for scheduling reasons, and you want to only have to make one sign and then add it to all the places where you need signs.
   Does that make sense?
Thank you very much for your help!
Nachricht 4 von 31
@rmarkowitz
You will have to sacrifice one or another.
If I were doing signs with LED tapes, I would create the sign as an adaptive family instead of a face base family.  The only additional steps for placing an adaptive sign versus a face based sign is you need to define placement points, which is fairly simple in my opinion.  That way, your adaptive LED tapes work without any further headaches.
Nachricht 5 von 31
rmarkowitz
als Antwort auf: ToanDN
Ok, I guess that's what I'll do then next time. I guess it's too late now, given that I already have lots of face based families placed, and replacing them all with adaptive families would take a very long time.
Thanks for the input!
Nachricht 6 von 31
RDAOU
@rmarkowitz
as @ToanDN said... you have to take one way or the other rather than mixing...the only thing you have to bare in mind with adaptive components, they do tend to make your model slow and heavy; especially in a case where you have lots of one element all over the model.
if it is just about adaptability to site...you might also consider using the template for Entourage families...those do work for signage and fences for instance. Revit isn't about an either or...one can come up with more than a handful of simple solutions without complicating one's life.
Many call these workaround and many call them "things one can do but shouldn't"...I call them short sighted with lack of creativity ...
not the families :leicht_lächelndes_Gesicht:
Nachricht 7 von 31
rmarkowitz
@ToanDN@RDAOU
If you don't mind me asking without my Revit in front of me - can you import and host a face-based family in an adaptive component?
Thanks!
Nachricht 8 von 31
@rmarkowitz
Yes.  A face based family can be hosted by a face of an adaptive family.
Nachricht 9 von 31
awasyliw
als Antwort auf: RDAOU
Maybe not in this case, but in others there are very good reasons for wanting to do this.
In my case I found that the tools you have access to in the adaptive family modeller are ideal for creating genuinely decent looking solid tree models... yet they can't then be brought in to a planting family.
Same would hold true for furniture etc... you are stuck with it being called a generic family.
It's frustrating to have the tools to model certain things better, yet not be able to tell revit what you want them to be.
Nachricht 10 von 31
als Antwort auf: awasyliw
Nachricht 11 von 31
awasyliw
Ok... looks like you achieved this... but how?
... never mind, I see how. I think maybe I did get there, but the problem is then that you can't have a detail plan symbol to go with it, as you can't load a detail item, or non adaptive family, in to this (or vice versa).
Nachricht 12 von 31
Just change the category from Generic Models to whatever you want that available in the list.
Nachricht 13 von 31
awasyliw
Thanks... sorry I replied too early. I think I had got there. edited my previous comment with the actual problem!
Nachricht 14 von 31
You can import CAD files in lieu of detail components.  See attached.
Nachricht 15 von 31
rmarkowitz
Not all categories are available in that list - including lighting fixtures.
Nachricht 16 von 31
Rockit_for_Revit
I need to use Lighting Fixtures category, is there a workaround for this?
Regards
David
Nachricht 17 von 31
als Antwort auf: Rockit_for_Revit
No dice.  Workarounds depend on how the lighting fixture look and how you want to use the it.
Nachricht 18 von 31
Rockit_for_Revit
An LED strip light with rectangular profile with various x,y,z points.
Kind Regards
David
Nachricht 19 von 31
rmarkowitz
I've literally built duplicate schedules for everything. I really wish this would be fixed!
Nachricht 20 von 31
If you don't mind me asking how did build create your adaptive LED strip? I have created an adaptive item to use for it but am having trouble attaching a light source. Is there any way to do so? Can the light source be nested and attached somehow?
Thanks in advance.
