User needs to login to BIM360 while linking a file in Revit
2 ANTWORTEN 2
Nachricht 1 von 3
abhinab.bardhan
283 Aufrufe, 2 Antworten
While linking a Revit project an error appears " [Filename.rvt] references Revit add-ins that are not installed" and the user is prompted to sign in to BIM360. However, the user was not working with BIM360. The files could be referring to the RCW / Desktop connector links. The requirement here would be suppressing the warnings coming from BIM360 and ignoring the message asking the user to sign in to BIM360.
Line 1>
Abhinab bardhan
Beschriftungen (1)
2 ANTWORTEN 2
Nachricht 2 von 3
@abhinab.bardhan ,
I'm going to move this over to the Revit forum...this is AKN article should help your user:
"[Filename.rvt] references Revit add-ins that are not installed" when opening Cloud Workshared Model...
Thank you!
Kimberly
Kimberly Fuhrman-Jones
Revit Community Manager
Nachricht 3 von 3
abhinab.bardhan
als Antwort auf: abhinab.bardhan
@kimberly_fuhrman-jones thanks for the insight but this AKN article didn't help resolve the issue.
Is there a specific way of suppressing warnings that comes from BIM360? Or if there are ways to avoid a BIM360 login request? Thanks!
Line 1>
Abhinab bardhan
