User keynote to attach to a free-hand markup
6 ANTWORTEN 6
Nachricht 1 von 7
HVAC-Novice
256 Aufrufe, 6 Antworten
I used "regions" to mark something up that I want to add a user keynote to. this is just an example that I want to let the contractor know there is a duct and that needs sprinklers underneath. The model doesn't actually have the duct. but thee could be different situations requiring similar
Problem is the user keynote doesn't attach to regions. in my example it is attached to the grid line.
what are my best options to accomplish this?
I googled and found the following hacks (with other problems):
  1. Place a detail item: Problem is, I need to be "in-place" and not a loadable family because it needs to make "weird" shapes. it seems detail items only are loadable families and not "in-place" like components under "Architecture"
  2. Place some other model element (like a dot of something): Problem is I need to place that family in addition to my region.
  3. I tried "note blocks" and those could work... but they seem very dumb in that they don't automatically number per sheet, and don't automatically number as they are placed (they could have two note "1"). They also seem to have the option to sort by sheet placed on in case I need them on different sheets. But then I need multiple schedules and need to manually enter the sheet number. This seems very un-Revit unless I'm missing something.
Any better workarounds to create a "weird shape" markup that I can tag notes to?
if there isn't a better way, I think out of the above options using user keynotes and attaching them to a neearby object may be the least bad solution
Revit version: R2025.4
6 ANTWORTEN 6
Nachricht 2 von 7
SteveKStafford
als Antwort auf: HVAC-Novice
You could model duct with about the same effort assuming the duct type and fittings are loaded into the template.
Steve Stafford
Nachricht 3 von 7
HVAC-Novice
als Antwort auf: SteveKStafford
There also is AHU etc. I only want to outline the area that requires sprinklers underneath or other obstructions.
I didn't design the HVAC for this project. But even for projects where I designed the HVAC, and have ducts in the model, I still wanted to have a nicely colored highlighted scope area and used the "regions" since they looked best. But only where required (i.e. not under ducts less than 4'wide).
Nachricht 4 von 7
SteveKStafford
My point is that a basic layout of duct would accomplish something similar and potential be helpful in the model environment too. If you want a region and to be able to use a User Keynote vs text element...then drop a "X" detail family on top and keynote it...
or break with tradition and model it as a ceiling or floor type you can then apply a keynote to.
Steve Stafford
Nachricht 5 von 7
HVAC-Novice
I probably should have used a different example. That "Region" also could be a marked up area for contractor to store material, or a piece of carpet I want to have installed.. or anything.
If I model something, I also have unintended consequences (i.e. it shows up in other views when to shouldn't). All can be dealt with, but it takes longer than using a "region".  and i still would have to make a modelled element to have a pattern and color I want to "highlight" this.
Here I need an "annotation" that only will live on that view. not "model" method that will be in the actual model.
Nachricht 6 von 7
SteveKStafford
You could sketch your weird shape in a filled region but then copy the lines to clipboard. Start a new detail item family, filled region and then paste the lines from the project's sketch. Quit the filled region in the project, load the detail item family, place it and then keynote it.
Steve Stafford
Nachricht 7 von 7
HVAC-Novice
I also need to edit that shape. In my example, I went on site and saw some equipment is actually oriented a bit differently. So the annotation tools (like regions) really work the easiest and I can edit the lines and quickly move them around.
