use same wall type but pattern not show when create new one
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
wanlapha
466 Aufrufe, 4 Antworten
Hello, I am trying to create wall number 2 same as number 1 (pic). I use wall type same as number 1 but it not show pattern or color be like number 1. I want to know method of setting pattern wall like this and how to use this.
and pattern of this wall type doesn't use material browser to setting surface pattern. this pic is material browser of this wall type.
4 ANTWORTEN 4
Nachricht 2 von 5
jvpantin2
als Antwort auf: wanlapha
Walls belonging to the same type must look the same always, unless an override were applied. Use Match Type Properties (MA) to verify this. Something else could be happening.
¿Tu problema fue solucionado? Selecciona 'Marcar como solución'.
Así ayudas a otras personas a encontrar respuestas y agradeces a los miembro de la comunidad.
Nachricht 3 von 5
kostask_oionei
Did you create both wall types?
If the screenshot shows the nr 1 wall material, the pattern was probably applied with "paint" command directly at the wall faces.
You have to find this pattern and put it to "surface pattern" -> foreground for apply to wall type.
If my post help you, please give a like.
If your question was answered please mark it with ACCEPT SOLUTION. This helps others to find answers...
Kostas Kouris
Architect Engineer, M.Sc., ACI, ACP
Nachricht 4 von 5
Looks like one wall is painted with a material and the other not.  The pattern on the end of the wall is what leads me to that assumption.
Nachricht 5 von 5
wanlapha
als Antwort auf: kostask_oionei
ok I can solute from a solution.I use paint directly change material wall. thanks.
