Hi Community,
Is there any way to set the "Name" as a Revit "Username" instead of "ID" while login to Autodesk account?
The reason for this question is..,
Few of my project, BEP call for controlled naming for the users. which is used to identify the user company and the name. If I log-out, I have the ability to change the "Username" but, cannot use some of the Autodesk cloud services.
What I need is the ability to use the custom Revit "Username" even I logged-in, into the Autodesk account.
Gelöst! Gehe zur Lösung
Gelöst von DarrenP. Gehe zur Lösung
you might have to change your username for your Autodesk Account under security settings here: accounts.autodesk.com
there is also this: https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
but never tried this
DarrenP
