Use of IfcExportAs to not export an object
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
sofiene.dahakT3WWH
348 Aufrufe, 3 Antworten
What value to use of ifcexportas to not export an object in the IFC export. I tested with ifcexportas = "Not Exported"  but the object is still present in the IFC mockup.
I know that it is possible to choose in the IFC configuration of revit not to export a revit category of object or to export only the elements displayed in the 3D view.
What I would like to know is if it is possible to use IfcExportAs to do this.
Thanks in advance,
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: sofiene.dahakT3WWH
I'm not sure I understand the point. Are you trying to set up an Export Setting to automatically detect elements that are NOT to be exported?   If so, why don't you do this through a View Template with assorted Filters?
Nachricht 3 von 4
se.ha
Hi @sofiene.dahakT3WWH,
it‘s „DontExport“ or „DONTEXPORT“.
se.ha
Dieser Beitrag war hilfreich? Dann könnt ihr diesen Beitrag gerne liken.
Hat dieser Beitrag die Frage erfolgreich beantwortet? Dann klickt bitte auf den Button 'Lösung akzeptieren'.
Nachricht 4 von 4
sofiene.dahakT3WWH
als Antwort auf: se.ha
Thank you @se.ha
It works perfectly. I thought there was a value in not exporting anything!
