Urgent!!! Spot elevation shoulder angle
1 ANTWORT 1
Nachricht 1 von 2
PrathapSekar
439 Aufrufe, 1 Antwort
HI Experts!!
Please refer the illustration below, (You could see the call out ant scope box in plane view right side)Call out and scope.jpg
 As shown in above image we have some tilted rooms/areas in our project, on that we have created a scope box and call out view, while placing spot elevation with shoulder in call out view its working horizontally, but while placing that on scope box view its looking tilted as highlighted. Please help us to place the elevation as we have in call out view.
We tried un-checking the shoulder check box in options bar. we need shoulder to place our spot elevation to avoid clash in some other areas.
Thanks in advance.
Thank You! and please 'Accept As Solution' when you found a solution, to help others.
1 ANTWORT 1
Nachricht 2 von 2
cbcarch
als Antwort auf: PrathapSekar
see if this helps:
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
