Urgent!!! openings in wall.
12 ANTWORTEN 12
Nachricht 1 von 13
PrathapSekar
2305 Aufrufe, 12 Antworten
Dear Members,
We need to show openings in walls to allow MEP components going through, For this we need a advice/Tip/Tool to place the openings little faster than what a person can do,
It would be great if we have a tool that allow us to place the openings with exact size and location.
Also we heard that we can do something with Dynamo, but we admit that we don't have knowledge in that.
Thanks in advance.
Thank You! and please 'Accept As Solution' when you found a solution, to help others.
12 ANTWORTEN 12
Nachricht 2 von 13
L.Maas
als Antwort auf: PrathapSekar
Yes, Dynamo would certainly be able to do this. However it will need that you invest time to learn it.
In the mean time have a look at THIS Revit MEP Clash-Point Hole-Cutting Tool (free).
I have not used it, but it looks a like a possible (temporarily?) solution for you.
(Next time consider posting this in the MEP forum, a more suitable place for MEP questions)
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 13
how about creating a wall based family with void forms. You can set parameters as you like.
Nachricht 4 von 13
bimscape
als Antwort auf: Anonymous
I like @Anonymous proposal. Seems the most straightforward and elegent.
You can create a number of Types in the Family for your most commonly used Opening dims.
Don't overcomplicate anything.
Kind regards,
Ian
Author of The Complete Beginners' Guide to Autodesk Revit Architecture (free online course)
Nachricht 5 von 13
You can build chases into wall types using Reveals too.
Nachricht 6 von 13
PrathapSekar
als Antwort auf: L.Maas
Thanks @L.Maas, we are using that tool, it's working fine but are struggling to get some result on this.
Thanks @Anonymous, @bimscape, We are using our custom void family. but what we looking for is to place this void families to the locations in automation mode.
Thanks @Anonymous, We have bunch of walls to place openings. so only we are looking for some short way to place this quickly.
Thanks all again.
Nachricht 7 von 13
- Create a 3D view that only shows duct categories (duct, fitting, insulation, etc...)
- Export to a SAT file
- Create an in place generic model and import SAT in
- Use Join geometry, tick join multiple box, and join the in place with walls or any elements need penetration
- Turn off in place family and you are left with penetration
(optional: temporary set duct insulation to a thicker type before export to SAT so that the penetration will be larger that the actual duct based on some tolerance criteria)
It is neither a dynamic nor parametric solution.  When ducts change you need edit the in place and re-import the updated SAT.  But after that the penetration will be automatically updated unless you add new walls.)
Nachricht 8 von 13
PrathapSekar
als Antwort auf: ToanDN
Great @ToanDN, is there any possible way, when placing tag that show invert level of openings?
Thanks in advance.
Nachricht 9 von 13
What tags?  Just use Spot elevation then.
Nachricht 10 von 13
Yes: put Invert Elevation field into the tag's label
Nachricht 11 von 13
TECHMINDS
More about this "Chase" please?@bradley
Nachricht 12 von 13
als Antwort auf: TECHMINDS
Basically pushing the Reveal inside the wall, cutting the wall cavity instead of cutting the finish layers.  Right? @barthbradley
Nachricht 13 von 13
Correctamundo, @ToanDN. That's what I was thinking at the time, but I don't think it applies here now. Smiley (zwinkernd)
