*URGENT* Cannot generate Energy Analytical Model
15 ANTWORTEN 15
GELÖST
Nachricht 1 von 16
2115 Aufrufe, 15 Antworten
I have an issue where everytime I would try to run an Energy Analytical Model through Insight 360, it would simply not process and constantly say that it has failed. Here is the specific message being sent to me via email:
"Detailed status:
Model: SolarRadiationAnalysis
Error: Issue: Your model has no conditioned spaces and will not be simulated. Green Building Studio requires that at least one space in your model be conditioned in order to carry out simulations. If you would still like to simulate the model, add one small conditioned space to the design."
Please, someone help me fix this, this is for an assignment that is due for this Friday and want to be able to fix this as soon as possible and nobody is actually helping me. I have tried to read up on this issue, to little to no luck. Attached is my Revit model (for Revit 2019).
15 ANTWORTEN 15
Nachricht 2 von 16
als Antwort auf: Anonymous
Do you have any spaces to analyze?
Nachricht 3 von 16
RobDraw
Have you seen this and the related pages?
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
Rob
Nachricht 4 von 16
als Antwort auf: barthbradley
@barthbradley I want to be able to analyze all the spaces within the first floor, yes. I have marked all the given spaces there.
Nachricht 5 von 16
You actually created a SPACE?  You can see it in the model?
Nachricht 6 von 16
als Antwort auf: RobDraw
@RobDraw I have tried looking through this, yes - but how would this help me successfully generate an energy analytical model?
Nachricht 7 von 16
@barthbradley Here is what I can see from the Energy Model here:
As it is, I made spaces that are visible in the floor plan, but not in the model. I do not know if this is the issue that I am having.
Nachricht 8 von 16
RobDraw
It's actually quite a complicated subject and I've got a few links. I clicked on the wrong one. Try this one:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2017/EN...
Rob
Nachricht 9 von 16
I downloaded and ran analysis. No errors so far. Confirmation email received .Let you know what the analysis results are when I receive it back.
Nachricht 10 von 16
Okay, if it works could you potentially send it over to me? Just because this has been bothering for the past few days and I cannot work it out.
Nachricht 11 von 16
Will do.
Just for future reference, there is an Insight Forum as well:
https://forums.autodesk.com/t5/insight-energy-forum/bd-p/2022
Nachricht 12 von 16
@barthbradley  Okay - thank you. Please do keep my informed on the progress of this and - if it doesn't work - why. If it does, then I would greatly appreciate being sent a screenshot of the successful run.
Nachricht 13 von 16
No issues to report. Here's analysis :
https://insight.autodesk.com/OneEnergy/Model/228979
Nachricht 14 von 16
Why did you pull my Solution Credit? Not cool.
Nachricht 15 von 16
@barthbradley  Thank you very much - I apologize, I wanted to make sure everything went through well before I could list it as solved. I greatly appreciate the help, and I thank you for it!
Nachricht 16 von 16
RobDraw
Rob
