Upgrading
Upgrading
Upgrading
Hi! I have a network license for building suite Pre 2014 with subscription, and now I'd like to try 2015 products, do I need to install network license for the new products, or can I run them with the existing license for 2014 products?
Thanks for any info.
Jenny
David_W_Koch
If your current network license file was created prior to the release of the 2015 products, then you will need to get and install a new network license file in order to be able to run the 2015 products under license.  (You could run them for 30 days as a trial, if you want to get started before you get the new license file in place.)
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Thanks David, that's all I want to know
