01:19 PM
I got a new laptop with Windows 10, and successfully installed Revit LT 2013. It works fine. But I can't open recent projects generated with the same version using Windows 8.1.
The Error message says "[project name].rvt cannot be opened in Revit LT because it was last saved in a version of Revit prior to 8.1"
I searched the Forums and the advice says to install the trial full version of Revit and to try opening either the main .rvt file or the backup file. I installed the trial version of Revit 2021, and neither will open. I'm not seeing any service packs for 2021.
