I upgrade my Door family from R16 to R17. The door working great in previous version of revit, but in R17 I can´t create duplicate type, because it makes me Error. I discovered my problem is formula door area(shared parameter) = Rough Height*Rough Weight - but this formula works
in family without problem. I can´t duplicat family in my project only.
Can you explane me my issue?
Thank you so much.
There is something in the family that isn't working correctly...if you duplicate the type in the family does it work?
Make sure you duplicate the wall type in the family and change the thickness to make sure the family doesn't break.
Or can you provide the family?
Hello, when I delet this formulas, famili work corrcet and type is it possible duplicat in family. In R16 it works without problem. I am confused of this.
Sure, here is family. When you clear parameter ,,plocha dveri" it will works in project....But formula is write correctly...
I am not able to reproduce the issue when I load the family into a new ootb project started with the US metric template...have you tried it in a different project or a new project to see if the issue occurs?
In Metric template it is work correct ... i do not understand. In my previous template it doesen´t work. But I used it 2 years.... oooh
Thank you for your help ![]()
Try doing a saveas on the family and change the name....load it into the project it isn't working in and see if it works ok...perhaps the original family became corrupt in the project somehow.
