Updating template in current projects
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
Sahay_R
6875 Aufrufe, 4 Antworten
Our Revit template is a dynamic being, which is constantly under review and updates.
What would be a reliable method to get a current project that is running under the old template into the new updated template?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
4 ANTWORTEN 4
Nachricht 2 von 5
kadmonkee
als Antwort auf: Sahay_R
open a new project with the updated template.
open the current project with the old template
in your current project transfer project standards (selectively) from the new project to the current project
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Nachricht 3 von 5
I do what @kadmonkee has mentioned with just one additional step. I first transfer the category of elements to an empty template and purge out what I don't need from that category, then I transfer to the actual project. Reason being, I often don't want ALL the linestyles or text styles etc, so this additional step allows me to bring in only what I need. Project parameters or materials is another example.
Nachricht 4 von 5
Sahay_R
als Antwort auf: Anonymous
I did try to Bind the old project to a new virgin project. Am I right to have been scared to death?
Rina Sahay
Nachricht 5 von 5
kadmonkee
as long as you are migrating sequentially you should be ok.
try to avoid skipping versions
only transfer what you need and do this in small steps (more Time consuming).
this will allow you to recognize any issues as they appear.
thank you
