While I'm opening an Revit 2014 file in Revit 2015, the filters in the file is not imported correctly. For example the filter Roof | Facia and Roof | Cutters categories are left blanc while they were checked in the Revit 2014 file...
you can try to use the Transfer Project Standards command to copy the filter back into the file.
1. open current revit project in 2014
2. save as new 2015 project
3. use transfer project standards to copy filters from old revit file to new revit file
4. check filter
Dzan Ta, AEE, ASM, ACI.
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
I've tried that option before I posted this issue. But dat won't work either. so it looks like it's realy a bug in Revit 2015 while opening previous versions of Revit. Now I've had to alter manualy 300 filters in my Revit Template 😞
I run update 2015 version 9 but no results so far.
i suggest you let autodesk tech support know so they can look at your files to help you. it's either a bug in the software or a corruption in your files
Please send to me the following:
company name
contact name
contact email address
Revit version and serial number
Revit files
description of exact nature of issue
I will send this up to Autodesk Tech Support and they will contact you to help.
