Using revit 2022, the masterformat version available wit the interoperability tool in the default folder: C:\Program Files (x86)\Autodesk\BIT\2022\Resources is 2010.
How do i update it to the latest version of masterformat i.e. 2020?
You can create your own database. In that same folder is an excel file "Classification Manager Database Custom.xlsx".
You can use that to build your own database.
I do not know how much is changed between those master format versions, so you can easily copy/past/edit it.
Or maybe you have already the data in another format which you can use to create thet new xlsx file.
I think the reason there is only a 2010 version is relating to Masterformat licensing.
Louis
Please mention Revit version, especially when uploading Revit files.
