Hi Forum,
I'm running into a small, but frustrating quirk - whenever I adjust my curtain walls, either in length or height, I'm finding that new (unwanted) mullions and curtain grids are appearing at the middle vertical point of my curtain wall.
Is there a reason for this? A way to prevent it from happening anymore - it can be time consuming when altering a lot of curtain walls ever so slightly to have to go through and delete the offending mullions.
Thanks in advance!
Gelöst! Gehe zur Lösung
Gelöst von joe_keogh. Gehe zur Lösung
Hi @amy_rutty
This is happening because you have Grid Layout defined in the Curtain Wall Type Parameters.
Edit the Wall Type Properties and Horizontal / Vertical Grid "Layout" Parameters values to <None>
You will likely be asked if you want to delete the automatically created Grids, to which you probably want to select no.
You may want to duplicate the wall type first so as not to affect any other walls.
