Unwanted Lines On Wall Joins
5 ANTWORTEN 5
Nachricht 1 von 6
1277 Aufrufe, 5 Antworten
I have joined walls in my project, some of which have unwanted lines in the joins. These lines appear to be the ends of the connecting wall.
I have tried the Wall Joins tool and cycled through the different possible joins, non of which get the result I am after.
Any help on this would be greatly appreciated.
Tags (3)
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: Anonymous
Are the red walls separate wall types?  Do they have the same heights?
...what happens when you miter corner?
...could it be related to different Layer Functions?
...Design Options?
...Voodoo?
Nachricht 3 von 6
als Antwort auf: barthbradley
The wall types are different how could this be an issue?
I have mitred the corner and that seems to have got rid of the lines.
I have attached an images of another instance of the issue which looks a lot more complex. Are you able to identify the error from this image?
Nachricht 4 von 6
Are you Joining? Have Automatic Join turned on the when placing walls?
About Wall Cleanup:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2017/EN...
This is what I was referring to when I mentioned "Function":
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
Nachricht 5 von 6
I am using auto join.
Thank you for your links i will check them out now.
Nachricht 6 von 6
RevitRx
If your wall assembly elements are ordered correctly and it still joins funny, usually there is another wall above or below your view that tries to join the wall in question. I'd make sure to check your stuff in 3D as well as plan to see if something else is interfering with your wall join.
www.RevitRx.com
