Dont know what i did, but switching from hidden line mode to consistent color mode.
all of a sudden these hidden lines keep showing up...
Gelöst! Gehe zur Lösung
Gelöst von syman2000. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
it works! thanks! I guess the view is just corrupted. My co-worker created too many warnings, but fixing some of them, the file seem running faster too..
Normally it is the eye elevation and target elevation is set way off distance. As a result you will see mess up lines.
To fix this. I just use the view cube click on the edge of cube and then it will reset the eye elevation and target elevation back to normal.
Thanks a lot, wondering why I cannot find any solution, this fix is really out of nowhere to find. Thanks again for sharing tips, this helps me a lot and save my time to reconfigure my model from scratch because of this annoying lines appears in my model.
Thanks a lot. This helps me a lot and saves me time in reconfiguring my views from scratch.
