unused area calculation and tag
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
550 Aufrufe, 7 Antworten
hi
i'm working in a project that the owners has a land with 100m² and i will build just 70m²
as shown in the picture the land border created by detail line
how can i tag this empty area and calculate the area?
i have tried the Area command but it use walls to define areas
7 ANTWORTEN 7
Nachricht 2 von 8
constantin.stroescu
als Antwort auf: Anonymous
I'll use Property Line for this with Tag(Annotation>Civil>Property Tag
Constantin Stroescu
Nachricht 3 von 8
constantin.stroescu
so , here are the steps:
  • in Site Plan View> Massing&Site >Property Line> Create by Sketch
  • Annotate > Tag by Category >hover  with Tab so to select the entire closed contour and click to select.
  • if the Tag is not load then you will be asked if you want to load a Tag. Answer Yes! >Load Family>Libraries>Annotation>Civil> Property Tag
  • You can use Edit Sketch to modify the contour...Area will update automatically
Constantin Stroescu
Nachricht 4 von 8
als Antwort auf: constantin.stroescu
thanks sir
can i show that area in schedules ?
thanks again
Nachricht 5 von 8
constantin.stroescu
yes, you can:
  • View >Create >Schedule>Schedule/Quantities>New Schedule>Site>Property Lines
Constantin Stroescu
Nachricht 6 von 8
constantin.stroescu
or , if you want to include the building then use a Gross Area Schedule:
Constantin Stroescu
Nachricht 7 von 8
how you could make an area without walls ?
Nachricht 8 von 8
constantin.stroescu
have a look at my screencast, maybe you'll find it somehow useful.
https://knowledge.autodesk.com/community/screencast/c1abbdc8-c47c-4064-b5f3-272bc570467d
Constantin Stroescu
