Unselectable text showing up as part of my sheet template.
On some of my sheets, there is un-selectable text visible behind my sheet set template. However when I go to edit the family it is not present.
It is also inconsistent and happens on different sheets showing different selectable text.
I have attached a screenshot of how it should be vs. what I see on certain sheets.
It is a revision schedule. Check Revisions under View tab.
Yes, I found this, thank you. But I cannot delete that revision set as it will delete all my rev clouds. How can I remove that label from the sheet? And why would it show up like that in the first place?
A revision schedule is placed on your titleblock family and it will list all any revisions assigned to the sheets in project (automatically if revision clouds appear, or manually via Edit revision on Sheet button from properties).  If you want to remove the revision schedule altogether, open the titleblock (or a make a copy) and remove the schedule.
m-de-lange
I am currently having this issue in our Titleblock families out of nowhere.
I have deleted the schedule but the labels remain unselectable/uneditable.
Any other possible fixes for this?
>send our family as attachement
