At the beginning, I modelling with view template. Revit ask me need to reload the model owing to version not up to date. After the reloading, there are duplicate views in VG. the VG is under the view template. And then I try to delete the view template and copy the view template from another thought transfer project standard. After that, the views of VG have duplicate 2/3/4 times. Any solution of that?
I'm confused. Give us the precise workflow to replicate your "issue" on our end and we'll explain what's going on. Maybe posting your file here would also help us to help you.
I don't know what you mean by saying "views in VG" or "views of VG" but your screenshot show DWG imports with some duplication.
Using Transfer Project Standards to transfer a View Template will add unplaced instances of linked files if that View Template has been altered to affect the appearance of those links. You can remove those links in Manage Links afterward or edit the source View Template so it is not altering the linked files first. For example, duplicate the View Template in the source and remove its influence over the links so the original View Template isn't altered in that project.
Steve Stafford
