Looks like the "Material" Parameter is associated to a Family Types Parameter. That's why it's grayed out. If you want to disassociate it, press the 3-dot button and set to "none". If you want to change the Material, use the associated Parameter. Currently it is using the Material that is assigned to the Furniture Category under Object Styles.
