Hi
Can anyone tell me how I can unjoin these walls? I want the small line to stop there where I put the blue arrow. I tried by using the trim/extend tool, but the two walls always merge.
Thomas
Gelöst! Gehe zur Lösung
Gelöst von FGPerraudin. Gehe zur Lösung
Hi @Anonymous,
One way of doing it is to use the "Split with Gap" Tool. The images below indicates how you can achieve this.
THIS ARTICLE is also a way in which you can control wall joins in Revit.
I hope this helps! ![]()
Rudi Roux
MSc | Digital Engineering Manager
LinkedIn
Revit Mechanical & Electrical Systems 2018 Certified Professional | Revit MEP & Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional | Autodesk Building Performance Analysis (BPA) Certificate
If this post resolved your issue, kindly Accept as the Solution below. Kudos are always welcome ⇘
Hi @Anonymous,
Or just select your wall, and right-click on the join handle > disallow join!
If you want the junction to be clean though, after you have unjoined, just join the geometries a different way (Modify > Geometry > join) I know, they are both called the same, but the result is very different!
Just when you join geometry, pick the right wall first (the thicker one if I remember well!)
Cheers,
François
Francois-Gabriel Perraudin
BIM management and coaching
Sorry - last point -
If you want a line to appear, you will ned two different materials for the two walls.. at least as material IDs
That's all folks!
François
Hi
The 'split with gap' tool was exactly what I needed. A bit inconvenient that the 'allow join- symbol' only appears when u use the 'split with gap tool though. Or am I still missing something?
Thanks for the help!
Well, it will appear as soon as the join is disallowed...
So it will appear if you right-click at the extremity handle of the wall and select "disallow join"!
Hi @Anonymous,
I'm glad that the "Split with Gap" tool helped you, it is quite useful in various scenarios.
Her is another way of doing things:
I used the "Allow Join" option and made sure that the smaller wall "Butts" against the larger wall, this will result in a separation line.
Kindly accept the post/s which help you as a solution to allow future users with the same query, to resolve their issue quickly.
Rudi Roux
LinkedIn
Hi @Anonymous,
Only a pleasure!
I'm glad the posts served as a solution for you!
Rudi Roux
LinkedIn
