Units of parameters when exporting as IFC
3 ANTWORTEN 3
Nachricht 1 von 4
628 Aufrufe, 3 Antworten
Hi everyone,
i'm trying to develop a 5D-BIM Project with Revit and iTWO. I've made the 3D-Model with Revit and got it imported in iTWO. It worked out well, with the only exception of the Units of the mass-parameters. In iTWO the values of the mass-parameters, which I previously created in Revit, are shown in kilograms, although I have defined ton as mass-unit in Revit before exporting the model data as IFC. I need the mass-values to be shown (calculated) in iTWO in ton.
Could somebody help me solve this problem?
Thank you very much in advance?
3 ANTWORTEN 3
Nachricht 2 von 4
Corsten.Au
als Antwort auf: Anonymous
You may create a Tag and in Tag you can use
more than one unit ( ex KG, Pounds, Ton ( I guess for this you may need custom calculation equation )
Best luck
Corsten
Building Designer
Nachricht 3 von 4
als Antwort auf: Corsten.Au
Thank you very much!
Best regards
Nachricht 4 von 4
whp.m.owens
I am trying to export my IFC to tonnes instead of kg.
Can anyone help me with this? I think the easiest way to modify this would be to declare the units as tonnes, but there is no clear ifc-documentation on how ot do this.
My preference would actually be to modify the unit within the custom mapping table, by chaning the mass format to a number...but then it doesn't export.
