Unit format - base point Proyect
11 ANTWORTEN 11
Nachricht 1 von 12
freeriderfx
588 Aufrufe, 11 Antworten
Why my base project unit are in Meters and not in gg°mm′ss″ (Sexagesimal System)
I want to put the real location of the project.
Any idea?
11 ANTWORTEN 11
Nachricht 2 von 12
als Antwort auf: freeriderfx
That doesn't make any sense.  Can you explain how would that work?
Nachricht 3 von 12
freeriderfx
als Antwort auf: barthbradley
Since when Lat/long are in Meters?
Nachricht 4 von 12
So my example of the Sexagesimal System has disappeared for no reasons?
Nachricht 5 von 12
You are looking at the wrong thing.
Nachricht 6 von 12
They are not.
I think you are confused.  Those a Cartesian Coordinates
...@freeriderfx, check this out:
https://revitpure.com/blog/13-tips-to-understand-revit-base-points-and-coordinate-system
Nachricht 7 von 12
freeriderfx
als Antwort auf: ToanDN
UTM.pngAlready Solved it, this will make it (UTM coordinates)
Nachricht 8 von 12
So you moved the Survey Point.
Nachricht 9 von 12
freeriderfx
UTM.pngI accquired coordinates from the CAD file and modified the family to get the "UTM coorinates"
Nachricht 10 von 12
Yes, by Acquiring Coordinates you moved the Survey Point.  I don't understand what you mean by you "modified the family to get the 'UTM coordinates'".  Can you elaborate?
Nachricht 11 von 12
freeriderfx
Intead of having "m" (meters) in the field I just added X,Y intead and "Elev" for elevationIntead of having "m" (meters) in the field I just added X,Y intead and "Elev" for elevation
Nachricht 12 von 12
Okay, so it doesn't say meters, but it is meters.
Something you ought to be aware of: Revit has a 10 mile maximum radius distance limit.  Read list AKN article:
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/CloudHelp/cloudhelp/2019/...
