I have several spaces with the same types of case work. But instead of having each type have a general key note, I would like each instance of the type have a unique key note similar to the way doors work. Any suggestions?
Leon
I don't see any quick replies to this one so maybe I can
help get the ball rolling. Unfortunately I have no
experience in construction to know what the builder
likes to see on construction documents, but I was just
thinking, what about legends? That's supposed to be
where information about elements go. Just a guess.
you can create a shared parameter and can edit that label/annotation to enter desired value at each location as unique value.
@leonwilliams919 wrote:I have several spaces with the same types of case work. But instead of having each type have a general key note, I would like each instance of the type have a unique key note similar to the way doors work. Any suggestions?
Leon
I think you might be confusing "keynote" with "tag". A unique keynote for each element of the same kind, such as doors, is not a keynote, then, but just a tag.
You could do something like this with a Note Block. Perhaps that will work for your situation.
