Unique Door, Window & Curtain Wall Marks to Multiple Linked Instances
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
1008 Aufrufe, 8 Antworten
Hi All
I need some urgent solutions to a Revit roadblock I have hit.  Here is a breakdown.
  • We have a host model which is the Building Envelope/Shell.  In this there are about 8 Levels/Floors.
  • We have about 8 Unit Types linked into this Shell Model.
  • Each Unit Type is copied multiple times per level/floor = the multiple Linked Instances (I have advised on this route of having linked models for each unit type over the model grouping method of the units as I have found the latter to get out of hand and result in issues in the model). This method handles units being work on separately/remotely in terms of design changes etc more efficiently, then reloaded back into the Building Envelope/Shell model to update all instances of that Model/Unit Type.
  • Regarding all Doors, Windows and Curtain Walls, all Type Marks have been handled in each linked model which populates into the Building Envelope/Shell model = Perfect.
Here is the problem.  I need each of these Doors, Windows and Curtain Walls from each linked instance to read a unique Mark per instance.  So for example if on Level 3 I have 5 instances of Unit Type A, and a Window in this Unit of Type Mark W01, I want each window to read a unique Mark per instance. So if I have these Unit Type A's on multiple floors, each floor must have a unique Mark:
example Mark: (Level 3 = 3-001, 3-002, 3-006, 3-009, 3-019), (Level 4 = 4-001, 4-002, 4-006, 4-009, 4-019), and so on.
I have been trying everything I can think of, creating instance parameters in the Shell model, shared parameters, searching forums....I am running out of options.  Does anyone have as good solution on how to get the above Mark instance to be unique for each instance placed?
Thanks in advance for any feedback/advice/solutions.
8 ANTWORTEN 8
Nachricht 2 von 9
Mirko.Jurcevic
als Antwort auf: Anonymous
The only thing I can think of which you can use is the Revit link Name parameter in the schedule.
If this solved your issue, please Accept it as Solution help other forum users with similar issues to find answers easily.
Mirko Jurcevic
My blog: www.engipedia.com
Try my Revit add-ins: Autodesk App Store
Nachricht 3 von 9
I don't understand the dilemma. The Link Project's Mark Value is not useful in the Parent Project.  Why would you be referencing it?  How are you referencing it?
Nachricht 4 von 9
Rename each instance of the link to reflect the prefix you want then add a combine parameter consist of that value and window mark to your schedule.
Nachricht 5 von 9
als Antwort auf: barthbradley
Hi, thanks for the feedback and sorry for my late response.
Correct, the Link's Mark is not useful in the Parent/Host project, however we need to tag these elements by:
  • Type Mark (which is no problem as these have been set in the links and therefore tag correctly in the parent/host project), and
  • Mark of each element (doors and windows in this case),
from the linked instances within the parent/host project on each floor plans.
If there is a way of doing so and assigning these Marks in the Parent/Host project that would be 1st prize. The tricky situation here is that these Marks must be unique to each floor (as each project is linked into the Parent/Host project and copied multiple instances on each floor and across each floor in the building.
For now, I am using each Revit Link Name in the Schedule with a combined parameter of Link Name+Mark.  This is all well and fine for the Schedule however that combined parameter does not tie up/show up on the tags on the floor plans for that element instances.  Maybe I am missing something, if there is a way to have that Link Name reflect with the Mark from that link in the tag I would take that.
If there are other solutions please I would be open to it.
Nachricht 6 von 9
als Antwort auf: Mirko.Jurcevic
Hi Mirko
Thanks for this solution, I have set up the Schedules like this with a combined parameter for the Link Name + Mark.  Works perfect for the Schedule.  But on the Floor Plans I need it to reflect in a tag as well, or something similar in the tag.
If you have any solutions as to how I can have the same combined parameter of Link Name + Mark (for each element instance) show up on a tag, that would solve the problem totally.
Nachricht 7 von 9
als Antwort auf: ToanDN
Hi Toan
Thanks for the suggestion, I am going with this.
If you know how I can set up my tag to show that Link Name + Mark in that tag, or similar, that would really solve the issue.  I have tried what ever solutions I can but am coming up with no luck on that.
Nachricht 8 von 9
For tagging, create different tag types with different  prefixes in the label.
Nachricht 9 von 9
Mirko.Jurcevic
Unfortunately, no. Those parameters will appear in schedules but not in tags.
There is one idea I have, but it's not "BIM", I don't like it since it's manual and prone to errors but it better than nothing:
Create multiple tag families (or tag types) with unique prefixes, and tag doors, each link instance with appropriate tag.
Also, tags do not support instance parameters so this approach may end in many, many types or families.
I am attaching sample of such family.
The result will be something as shown in the picture:
Mirko Jurcevic
