Unify section lines in all views
4 ANTWORTEN 4
Nachricht 1 von 5
fernandovalbuen
224 Aufrufe, 4 Antworten
I want to unify all the section lines in all views (like the screenshot below) because the lines are messy. I can unify that lines one at a time, but I need to unify that lines quickly. Thanks.
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: fernandovalbuen
Nachricht 3 von 5
fernandovalbuen
als Antwort auf: barthbradley
unfortunately the video is of grids and levels, not sections, however thanks
Nachricht 4 von 5
Ah! Sorry. Are Section Tags set to Continuous - not Gapped?
...under Additional Settings=>Section Tags
...Actually, I'm seeing it differently now.  Open your Object Styles and check your Section Line Settings.
Nachricht 5 von 5
Not that I would do but you could turn off the actual section lines, place section reference other view, stretch it how you want, and copy paste aligned to all other applicable views.
You can post you original request to the idea forum, or search for a similar request and upvote it.
https://forums.autodesk.com/t5/revit-ideas/idb-p/302
