Uniformat Assembly Code, OmniClass Code For a Window Model
12 ANTWORTEN 12
Nachricht 1 von 13
2468 Aufrufe, 12 Antworten
Hello every one,
I am trying get Uni-format Assembly Code and Omni-Class Code for my window model.
I followed all the steps that mentioned here:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2014/EN...
But when I click Edit Type. I found no assembly code as in Fig.1 and when I click it appears as in Fig.2. So pleas I need help as soon as possible.
12 ANTWORTEN 12
Nachricht 2 von 13
als Antwort auf: Anonymous
go to Manage=>Additional Settings and load it into project/family.
Nachricht 3 von 13
Thank you for reply , but I can't find what you mean
Nachricht 4 von 13
As it's already a family project
Nachricht 5 von 13
really? Then I guess it's resolved. Right?
Nachricht 6 von 13
als Antwort auf: barthbradley
No the problem still exist :enttäuschtes_Gesicht:
Nachricht 7 von 13
Do you have this folder (or similar, depends on your locale)?
Nachricht 8 von 13
als Antwort auf: ToanDN
This is what I found:
Nachricht 9 von 13
Make sure your library folder path pointing to this location.
Nachricht 10 von 13
should I download the UniformatClassifications text documents and the RevitKeyNotes , and paste this files in this location ?
Nachricht 11 von 13
Yes for keynotes and uniformat. Omni is in another folder.
Nachricht 12 von 13
no .. not yet.. please help :enttäuschtes_Gesicht:
Nachricht 13 von 13
FGPerraudin
Hi @Anonymous,
Do not panick,
Toan and everyone is right.
You just need to inform Revit as to where the external file containing your assembly codes exists.
First, check the default location for the file (C:/ Program Data / Autoresk / Rvt 20XX / Libraries / desired library)
If not there, you will have to download it. File is called UniformatClassifications.txt - you can find it on the web or copy paste it from another workstation.
Then use the manage > Additional settings > Assembly codes window (sorry for my french.... lol)
Go and get your file, validate.
Validate and there you go!
Now you can assign an assembly code to your object!
Cheers,
François
(PS: all I did was reorganise the whole conversation, so thx everyone)
Francois-Gabriel Perraudin
BIM management and coaching
