Hi, at the left side strongly visible, due to resonable shading different slopes get different degrees of shading, I wonder, if there is a way to make all roofs in the shade take exactly the same grade???
Thanks!
You can set Ground Level at a specific Level so that shadow appear on a flat ground. But I don;t see any problem with what you have, it is more realistic that way.
@barthbradley @ToanDN didnt work, our management wants to have the plans in a more abstract style, shading of the sloped roofs ok as long as they all take the same shade of gray..
