Unicode control characters problem in revit 2018
iftah
Message 1 of 16
iftah
Text rendering in revit 2018 doesn't respect contol characters as expected in right to left languages(Hebrew,Arabic). See example below.
In Revit 2017 it works fine (except after line breaks whitch also needs fixing).
The issue is critical for firms working in RTL languages.
Replies (15)
Message 2 of 16
Viveka_CD
Hi @iftah
Can you try and install updates, open the Autodesk desktop app and click My Updates. To install a new version of your Autodesk software, open the Autodesk desktop app, sign in, and click My Products. To use a web browser to install updates or a new version, sign in to Autodesk Account.
(Your access to new versions or updates depends on your Autodesk software entitlements.)
Run the file and let us know if you still have the same error.
Message 3 of 16
iftah
I installd Revit 2018.0.1 Hotfix and it didn't help.
I tried creating an new Revit 2018 file from scrach (the first file was an upgraded Revit 2017 file), and still same error.
This means that the error isn't related to a specific file, but to the revised text rendering engine in Revit 2018.
Message 4 of 16
Viveka_CD
Hi @iftah
Can you try the steps below and let us know if this works?
  • Open the text file using a text editor (such as Notepad), and use the Save As command.
  • In the Save As dialog, change the file's encoding from ANSI to Unicode, and save the new file - for creating keynotes using a language that requires a script supported by the Unicode Standard,
  • Now you can use Unicode characters in the file. In Revit, open the Keynoting Settings dialog, and use Browse to select the new keynote file.
Message 5 of 16
iftah
Hi Viveka,
The porblem I broght up is in lables, text notes and scheduals. not keynotes.
The example in the first post is of a lable in a titleblock family.
(It might be in key notes to. didn't  run into it yet)
Message 6 of 16
Viveka_CD
Hi @iftah
Thanks for clarifying.This issue is being investigated for a possible cause and resolution.
Meanwhile can you confirm your Windows 10 version number? I recommend that you change the settings as mentioned HERE
Let us know if you were able to resolve this issue.
Message 7 of 16
iftah
Hi Viveka,
Windows 10 Home, Version 10.0.15063 Build 15063.
I change my system local from English(US) to Hebrew(IL)
It didn't solve the problem, and also created a new one: When Editing dynamic dimentions and tags, the text box shows giberish. see attached screenshot.
Meanwhile Im back to english local.
Message 8 of 16
Viveka_CD
Hi @iftah
Do you have the Segoe UI font installed?
Can you send us a file to test?
Let me know if you have questions regarding attaching/sending the file.
Message 9 of 16
iftah
Yes. We have Segeo UI.
I have attached a titleblock with the lable that examples the bug. (I Converted the font to Sego UI. It didn't help)
Meanwhile I figured out that the bug is only in lables. Scheduals, Text Notes and Keynots work same as in Revit 2017.
Message 10 of 16
Viveka_CD
Hi @iftah
Thanks for sending across the file. This is being investigated for a possible cause and resolution.
Meanwhile we tested with another Hebrew font and it works fine in Revit 2017 and 2018
Message 11 of 16
Viveka_CD
Hi @iftah
We are in the process of testing your file. Meanwhile can you please send the font file and a sample from Revit 2017 which worked for you?
Message 12 of 16
Betsalel
Hi Viveka,
I attached a title block created with Revit 2017 and the same file opened and saved in Revit 2018.
I used the default Arial font label types. These files where created on a different PC in a different firm. the PC local is set to Hebrew(IL).
Message 13 of 16
Viveka_CD
Hi @Betsalel
Thanks for sending the files across.
can you confirm if you are in the same office @iftah or you are a new user?
Message 14 of 16
Betsalel
Hi Viveka_CD,
The issue was resolved by the developers in revit 2019.
Thanks for forwarding it to them.
Message 15 of 16
Viveka_CD
Hi @Betsalel
I received your note and thanks for your message. I'll pass it along!
Cheers,
Message 16 of 16
emtanes
i am using revit 2025 and i have a simillar problem when using keynotes in floor plans i write in hebrew and english and the text is readable but when going into the keynote block the text just flips and isn't the same as in floor plans image.png
is there some way to make the keynote block match the text written in the floor plans
