How to unfold a curtain panel modeled in AutoCAD to prepare shop drawings in Revit. The Panel thickness is less than 8 mm. Is this possible to do in Revit?
I have attached the file for reference. Can someone suggest me a best possible solution.
Gelöst! Gehe zur Lösung
Gelöst von L.Maas. Gehe zur Lösung
No, Revit is not a product modeller. It has no unfold functionality. There have been some experiments in combination with Dynamo, but would not expect too much of it. For this kind of functionality you would be better of with Autodesk Inventor or similar programs.
Louis
Please mention Revit version, especially when uploading Revit files.
