Unexpected Size problem
13 ANTWORTEN 13
GELÖST
Nachricht 1 von 14
696 Aufrufe, 13 Antworten
My revit file is too heavy, 165Mo approximatively.
I found that the size of the .rws located in the backup folder is the same as the revit projet file.
So I tried several things as listed below :
- Deleted everything
- Unlinked everything
- Purged everything
- Deleting all sheets, unused views
But it remains heavy...
I know that the person who was working on this project used a pointcloud, an imported CAD file and rasters images.
I think the problem is with the rws file who seems embedded to the revit file.
I tried every basic solutions I found on internet or this forum before asking.
Is anyone already had this issue ? Do you have some advices ?
Thanks in advance.
13 ANTWORTEN 13
Nachricht 2 von 14
Kimtaurus
als Antwort auf: Anonymous
165Mb (or Mo) isn' that large to be honest. We've got projects up to 1 Gb.
Have you tried Save As instead of Save ? This usually shrinks the size a few Mbs.
Open the project using the Audit tool and next Save As.
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
Nachricht 3 von 14
Stanis-74
1. open file with ON checkbox "audit"
2. manage > purge unused
3. manage > manage links
4. insert > manage images
5. save the project with new name
6. check your family Lib. maybe some of your families is too heavy.
if it isn`t help, please show your model (jpeg of your 3d)
Nachricht 4 von 14
als Antwort auf: Stanis-74
Thanks for your suggestions
I tried what you said but didn't work.
I deleted every object in the scene so I got 0 objects, 0 families, etc.
That's why I found this very weird !
Nachricht 5 von 14
Kimtaurus
Again, have you tried to Save As?
Nachricht 6 von 14
als Antwort auf: Kimtaurus
Yes. I tried to save as
Nachricht 7 von 14
Kimtaurus
Can you show a screenshot of the 3D of the model, so we have an idea of the size of the project?
165Mb really isn't that big, unless you've modelled a bungalow or something small.
Nachricht 8 von 14
I deleted all the model to see if it was a familly or an other object that increase the size but it seems not.
So I got 0 model, my viewport is empty. That's why I found this very weird
Nachricht 9 von 14
Kimtaurus
There has to be something lingering in the file, can you upload it or post a download link?
Nachricht 10 von 14
Here is the download link : https://we.tl/9A6Nag6NQ3
Let me know ! Thanks to helping me :leicht_lächelndes_Gesicht:
Nachricht 11 von 14
Kimtaurus
The file size was due to 2 DWG imports.
I managed to select them with Dynamo.
The number in green is the element ID. Use the tool Select By ID to select the imports, unpin them and delete.
After deleting them, the file size went down to 2,26Mb.
In the future avoid importing a dwg, instead use Link. It's easier to remove these instances (Manage Links).
Nachricht 12 von 14
Great !
Can you explain me how did you manage that in Dynamo ?
Nachricht 13 von 14
Stanis-74
file became 2mb vhen i delete "Nuveau RDC"Level so.... there is ouf files
Nachricht 14 von 14
Stanis-74
you don`t need Dynamo. You can use standart app from ModPlus.org
you can find this dwg and delete them from this window:
