Uneditable curtain wall
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
dian4189
268 Aufrufe, 4 Antworten
Hello, I am trying to do a curtain wall storefront, so I can edit the grid lines and with wonder sizes, but I can't do it anymore. When I am trying to select only one panel or a grid to edit its width of it, it only selects the entire curtain system. Is that because of the new update or something? Since I could do it one month ago (worked a lot only with curtain walls).
4 ANTWORTEN 4
Nachricht 2 von 5
mhiserZFHXS
als Antwort auf: dian4189
Can you not tab through the different elements?
Nachricht 3 von 5
dian4189
als Antwort auf: mhiserZFHXS
No, it doesn't allow me to do it at all.
Nachricht 4 von 5
mhiserZFHXS
I'm guessing you need to toggle "Select Pinned Objects" then.
Nachricht 5 von 5
dian4189
Obviously, it was turned off for some reason. Thank you a lot!!!
