Hi all,
I am trying to build the Foundation/Lower Floor Plan using the Ground Floor as my base because most of the walls line up between floors. But, when I use the Ground Floor Plan as my underlay, I see the Roof Plan and not the Ground Floor Plan.
What I am doing wrong ??
Doug
Gelöst! Gehe zur Lösung
Gelöst von doug.johnston. Gehe zur Lösung
The Underlay property works together with another property called Underlay orientation. Check if the value of this other property is set to plan or reflected ceiling plan.
I finally figured it out ...
I needed to turn off the Roof in Visibility?Graphics Override on the Lower Floor Plan to see the Ground Floor Plan underlay.
I still don't understand why that had to happen, but it works !!
Doug J.
