Underlay turned on when plans drawn
7 ANTWORTEN 7
Nachricht 1 von 8
380 Aufrufe, 7 Antworten
Hi All, i accidentally drew my site plan with an underlay turned on, so now when i turn it off items disappear. Is it possible to correct this or do i need to have this plan set with the underlay turned on to levels they were drawn in (not ideal), thanks for your help
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: Anonymous
Which level does the Underlay indicates?
Nachricht 3 von 8
als Antwort auf: ToanDN
If Underlay at Base level ground floor and top level top of pitch it captures everything drawn, when i change levels i loose items drawn. Obviously i should have not drawn with overlay on but is there a way to reset underlay to off or should i just vive with the underlay turned on for this plan, thanks Toan
Nachricht 4 von 8
It sounds like you drew stuff on a different level. Open the base level and check if they are there. Feel free to post your file here.
Nachricht 5 von 8
 No i drew items on correct levels, does having underlay on when drawn determine what levels they appear? If not then must be a visibility setting
Nachricht 6 von 8
Changed underlay back to none and adjusted view range and the site plan items are there.
So seems drawing items on a plan with underlay set to a level does not have an effect on where the items are drawn (i think).
Can draw quite complex buildings but View Range always rattles me!!!!!!!!! ill find a simple explanation one day
Nachricht 7 von 8
cbcarch
Make sure to Set Workplane first, before modeling anything, to make sure what Level/Plane the objects are associated with.
Architecture Tab>Set Workplane> Select Level or Pick a Plane or Line
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 8 von 8
als Antwort auf: cbcarch
Hi Cliff, Sorry for late reply been away, good tip did not think of this
