I need to show on my foundation plan where the studs land on the foundation walls. Unlike in autocad, I can't just place my stud block on my foundation.
My thoughts were to do a plan underlay of the main floor. Then, using the line work override, select the studs with a thin line so they permanently show on the foundation page. The nice part about the line work override is, I can turn the plan underlay off and it will still show the lines I selected. Also, if I move the wall, it will show the changes on the foundation page. The problem is, the plan underlay doesn't show all details. It only shows the exterior portion of the walls. I need to show the studs.
Does anyone have another idea of how to do this or know how to show the studs in the plan underlay?
__
I have attached 3 images showing an example of what I would like to do. In the example I have used a door instead of walls. But the concept is the same.
