DESCRIPTION: Currently working on a crawl space plan. I am trying to set the underlay to view the first floor (right above the crawl space). Setting the underlay feature does not reveal the walls on the first floor above.
Checked so far:
-Phase filter (phases are default and not used in this file)
-View Range
-Hiding/deleting the first-floor floor
-Hidden Elements
Image description: Note the double joist locations should correspond to a wall above. I am unable to line up the double joist without view the underlay of the walls above.
The file is attached.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
