UNDER-CABINET LIGHTING NOT SHOWING IN RCP
8 ANTWORTEN 8
Nachricht 1 von 9
1214 Aufrufe, 8 Antworten
Hello I am new to Revit and I need to be able to show under-cabinet lighting in my RCP. It is underneath an extrusion that I created. I changed the visibility settings to show in plan view/RCP view but still nothing. The lines shown in the photo are just detail lines I drew to get them centered. Any ideas?
8 ANTWORTEN 8
Nachricht 2 von 9
als Antwort auf: Anonymous
Maybe a Masking Region from another Mother is covering it? Post the file.
...do you see it in Wireframe?
Nachricht 3 von 9
als Antwort auf: barthbradley
I'm new to Revit so I'm not sure what a masking region is. No I can not see it in wireframe view either
Nachricht 4 von 9
Not in Wireframe either? Rules out what I was thinking. Can you post the file? Be quick and painless. Promise.
Nachricht 5 von 9
Like post my entire model?
Nachricht 6 von 9
Like that's up to you.
Nachricht 7 von 9
bin
What's the View Range setting in that view?
Nachricht 8 von 9
Your undercab lights are likely below the cut plane. Lower the view range cut plane.
Nachricht 9 von 9
Based on something you said, I think I know what's going on.
Anyways, you said that you "changed the visibility settings to show in plan view/RCP view but still nothing". Was this being done in the Family itself. What did you expect to happen in the Family? Nothing will happen in the Family if the Preview Visibility is turned OFF at the time.
