Unbinding links doesn't work
6 ANTWORTEN 6
Nachricht 1 von 7
wn2WDLN
265 Aufrufe, 6 Antworten
What's the best way of putting an existing project into a new template?
I tried different things like copying the 3D geometry into the new template. I copied all at once and even tried copying the elements one by one. Doesn't make a difference.
I tried emptying the "old" template and transferring the new views from the new template by different ways. Then i can import everything exept the views (floor plans, elevations, etc.)
I tried linking the revit model and unbinding the link.
By every try i got the warning as shown in the image. No matter if i click Yes (ja) or No (nee) the action gets undone and we're back where we started.
Can someone please help me out?? :zwinkerndes_Gesicht: Thanks in advance!!
6 ANTWORTEN 6
Nachricht 2 von 7
EATREVITPOOPCAD
als Antwort auf: wn2WDLN
  1. Open existing project
  2. Open the new template (same Revit instance)
  3. Go to an existing project, Manage Tab -> Transfer Project Standards
The definition of insanity is doing the same thing over and over again and expecting different results
Nachricht 3 von 7
wn2WDLN
als Antwort auf: EATREVITPOOPCAD
That will transfer everything exept the plan views, etc... I already tried that
Nachricht 4 von 7
Can you open that file independently with Audit checked and inspect and resolve Warnings?
Nachricht 5 von 7
Wait a minute. "Unbinding Link"?  What does this mean?  Do you mean "Ungroup"?
Nachricht 6 von 7
Transfer Project Standards is the easiest option. Why do you need to use floor plan views from the template?
Nachricht 7 von 7
If you are trying to ungroup a group created by Binding a Link, and that group contains geometry, such as Walls, that have attached relationships, I can see how that could cause havoc.
See this:
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/3PP-REV...
"Don't use attached relationships in groups. The top constraints of walls are commonly attached to levels or other hosts like floors and roofs, but these relationships should be avoided in groups."
