for some reason, I'm unable to view images users post with the questions/comments.
is there a setting that I am missing?
Gelöst! Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
Hi @htews
Can you forward the link to the thread with images that you are trying to see?
Which browser are you using?
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
take a look at "a new wall parameter". shows an image icon and when i hover over it, says that "contains an image". i can see/download those who attach an image.
Hi @htews
Can you please share the link to that specific post?
Viveka CD
Thanks for the link @htews
I am able to see the images. I tested on chrome/ firefox and safari
I'm wondering if clearing your browsing data, clearing %temp% folder, removing some extensions on your browser, resetting to default might help.
I'm not sure what browser you use, but the below may resolve the issue:
Please select the Accept as Solution button if my post solves your issue or answers your question. Likes welcome!
Viveka CD
Chrome.
yes to the Show all images.
while I am asking, is there a way to NOT download an image to view the attachment?
This is what I see
Hi @htews
This is how I see it and I can save it on right-clicking on the image:
2. If the above steps don't work, create a new user.
3. Also, try toggling hardware acceleration: Go to Chrome Menu > Click Settings > Click Show Advanced Settings > Under 'System' uncheck/check Use hardware acceleration when available > Restart Chrome.
You can also try Chrome Canary
It's a future developer version of Chrome with all the latest updates and features. It's possible the problem won't exist in a future version.
Let me know if this helps!
Viveka CD
actually, it something to do with my forum settings. I can see the images when I'm NOT logged into my account but when I log into my account, the images are not there.
I see what you are saying. Let me see if I can get more help.
Viveka CD
OK @htews
I contacted the forum moderator, and they had a peek at your profile settings.
Apparently, you had 'html' turned off in your account so seeing embedded images was impossible.
The moderator has turned it back for you. let me know if you can see the images now! ![]()
Please select the Accept as Solution button if my post solves your issue or answers your question. 'Likes' welcome!
Viveka CD
Hi @htews
I'm glad to hear that.![]()
I think this is a moderator feature which is controlled internally.
Viveka CD
