I have a linked revit file with rooms created in it. I'm unable to use these rooms when creating sheets.
what might I be missing, or is is it not possible?
@Anonymous wrote:I'm unable to use these rooms when creating sheets.
This doesn't make sense. Perhaps, do you mean you can't tag the rooms?
I can do everything else including tagging, hense the picture for example. It's only creating sheets at which it disappears.
I've never used rooms to create sheets. I don't even see it as an option. Is that a 3rd party app? Maybe the rooms need to also be in your model. Contact the author of the app to find out more.
it looks like you may be using a 3rd party application?
What version of Revit are you using?
where is the Create Views tool in the Revit ribbon?
if you are using a 3rd party application, you may want to contact them, sounds like a issue in there app.
Howard Munsell
What do you mean by "see" the rooms? Do you mean you cannot see the Reference or Interior Fill or Color Fill or Walls or what?
