Unable to update template to Revit 2021
35 ANTWORTEN 35
Nachricht 1 von 36
Aryen_Jacobs
3067 Aufrufe, 35 Antworten
HI,
Well as title says. When i try to update our template to revit 2021 it crashes. Tried moving the template local so it wouldnt have network issues. Tried updating with Audit on also crashes.
This was the last step for us to continue working in Revit 2021.. the one i thought wouldnt be a problem but here we are :grinsendes_Gesicht:
Anyone any suggestions?
Beschriftungen (3)
35 ANTWORTEN 35
Nachricht 2 von 36
als Antwort auf: Aryen_Jacobs
Does your Template include 3rd party driven content -- content that is dependent on an Add-in that is not installed on 2021?
Nachricht 3 von 36
Lance.Coffey
Hello @Aryen_Jacobs, thank you for the question!
Some other items to check (beyond missing add-ins that barthbradley mentioned):
  • If upgrading more than one version, try upgrading the template to one newer version, and see if that is successful.
  • Try creating a new project from the template, and check if the new project will upgrade to the 2021 version.
It would also be helpful if you could attach a journal file recorded when trying to upgrade the template/project.
Lance Coffey
Technical Support Specialist
Nachricht 4 von 36
Tom_Kunsman
curious, what version were you upgrading from?
Nachricht 5 von 36
Aryen_Jacobs
als Antwort auf: Lance.Coffey
So we have been stuck in revit 2019 for a few years because of my inability to get our workflow working in the newer versions. Now i have found a solution. and now the easiest step istn working XD. So our template we work from is the 2019 variant with the most recent update 22-06-2020.
Until now i have tried the following(also tried these steps with audit on):
template 2019 to template 2021  ->crash
template 2019 to template 2020 to template 2021   ->crash
project 2019 to project 2021  ->crash
project 2019 to project 2020 to project 2021   ->crash
2019 to 2020 works fine
I did find a old version of the template from 2018 so its old and outdated and missing a lot of content. But that one worked going directly from 2018 tot Revit 2021.
I did find something on the autodesk help thing. it said some familys might be corrupted. but how am i supposed to find what familys are corrupted? there is no error report or anything
Nachricht 6 von 36
Aryen_Jacobs
als Antwort auf: barthbradley
Not as far as i know. i only use stock revit things the only 3rd party stuff i use are exporters.  Could it be that some familys are from a 3rd party library? because i have some of those mostly just symbols
Nachricht 7 von 36
ennujozlagam
it could be loaded families are from lower versions thats why it crashed? just saying. thanks
Nachricht 8 von 36
Aryen_Jacobs
als Antwort auf: ennujozlagam
I am sure its one or even more families thats corrupted.. but how do i find which one? the template has about 3k items
Nachricht 9 von 36
You can export all of your families to a folder - as they export it stops if a family has an error.  This may indicate the troublesome families. Right click on families in the browser and choose 'Save'.
There are also Batch Family upgraders available.  It may work to export your families as suggested above, upgrade them, purge the originals and reimport them.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/sfdcarticles/sfdcarticles/B...
Also ask if you need so many familes in your template.  I would advise having fewer, with an easy access library to bring relevant families into your project when required.  Your template file must be rather big, which hinders performance.
Nachricht 10 von 36
Aryen_Jacobs
als Antwort auf: Anonymous
Hey i tried to find the corrupted family.. well there are 6. deleted all 6 an did the export again. all exported fine. tried to update the file to 2021 and again " a serious error has occurred"
Nachricht 11 von 36
Perhaps you could try and purge all the families from the file, check that there are no warnings, save, close and reopen (with Audit) and then try and upgrade.  Reload relevant families and save it as the new template.
Nachricht 12 von 36
Lance.Coffey
Another way to check for bad families would be to Audit the file (may need to make a project to do the Audit), and then review the journal for lines like: ' 3:< [Family Name], LoadedId = [Element#], GUID = 6ec8b336-60db-4ece-84d9-f9ff6da57711, refers to a NON_EXISTENT_CONTENT_DOC. Please reload!
The following article has more details on this process: File will not synchronize in Revit
This could catch some that exporting families would miss (the families that wouldn’t export could potentially block the Audit operation, so you need to clear those first before you can Audit).
Lance Coffey
Nachricht 13 von 36
Aryen_Jacobs
Thanks for the tip. i tried it but it didnt work.  After that i tried to remove all familys that can be removed from the template. it still crashes when i try to update it.
Nachricht 14 von 36
martijn_pater
Make a whole new template for rvt2021...?:denkendes_Gesicht: Probably something to be said for a clean template...
FWIW: Did you try purging (*3..) down to the essentials, lineweight settings/company view templates etc...and clear all families that shouldn't really be in the template from the project browser, except annotation family/company standards probably... a lot of families I come across should be in an external family library file anyway, not in the template... edit: actually what @Anonymous said above...
Nachricht 15 von 36
Aryen_Jacobs
als Antwort auf: martijn_pater
True but that will be a massive time investment. and i dont think my boss is willing to take me off projects for a few weeks to actually make it.
And yes i tried. i even tried with all families purged. and it still crashes. the only thing that works is purging everything.
Nachricht 16 von 36
Post your 2019 template here.  Perhaps we can identify what's causing the trouble.
Nachricht 17 von 36
Aryen_Jacobs
I have thrown this at Autodesk support. Even with all families and materials purged it crashes when updating. The only thing that seems to work is pre 2019 templates or a empty one.. So there is something broken in the 'core' of the template.
But rebuilding the template from scratch would cost about a month to do and in that time i wouldnt be able to do any projects. so yeah it would mean a month of wage and no production. Why it takes so long to do: we actually use BIM for our own benefit. daylight ventilation fireprotection and several other stuff we need for permits (which means we need it EVERY project) have been automated/semiautomated. That takes a lot of paramters a lot of filters and what not.
Nachricht 18 von 36
Nachricht 19 von 36
Aryen_Jacobs
I have added the version without all families and stuff but it still crashes. (apperently it doesnt allow for template uploads so i have to send it as project)
Good luck and have fun. I wouldnt know myself how to find out what the problem is so if any of you can it would be great. so i can fix it and move on XD
Nachricht 20 von 36
I opened your template using Revit 2020, with Audit checked and then saved it. It crashed when I tried to open it in 2021.
I then purged the file in 2020 and resaved.  I could then open it using Revit 2021.
I unfortunately only have 2021 in trial mode at the moment, so I can't save it and repost it, but you could try the
same steps.
