Unable to sweep profile against stairs
2 ANTWORTEN 2
Nachricht 1 von 3
555 Aufrufe, 2 Antworten
Images attached
Im try to recreate these two areas from a Sketcup model in Revit.
I have created a profile for the sweep from a CAD detail and saved as a Revit profile family.
The sweeps on one level are fine - as per images.
I cant get the profile and path to sweep against the stairs - as per Sketchup screenshots.
Any ideas.
thanks all.
Beschriftungen (5)
2 ANTWORTEN 2
Nachricht 2 von 3
hmunsell
als Antwort auf: Anonymous
for your sweep path, try using the Pick Line tool and pick the underside of the stair.
Howard Munsell
Nachricht 3 von 3
It's not clear to me what you are describing. Sounds like you are saying that the Sweep Profile is not extruded along the full extents of the  Sweep Path. That is is being "broken" at the Stair Instance.  Are there Sweeps being done as an In-Place Component?  Post your RVT file. That would be best.
