Unable to select room separators in plan view by selection via window
liMVT68
Message 1 of 22
liMVT68
Hi Revit users! Not sure this has happened to me before, but suddenly unable to select room separators (a group of them) all at once in floor plan view. I can definitely see them, but if i click and drag a window over them, they will not select. I am able to select them one by one, but would love to have any input to see whether anyone has encountered this and is able to help? This is in Revit 2022. Thank you!
Replies (21)
Message 2 of 22
Crossing-window selection?  Lower right to upper left?
Message 3 of 22
Are you in a Design option?
Message 4 of 22
liMVT68
yes, both window drag selection does not work.
Message 5 of 22
liMVT68
yes, but even if i uncheck "active only" i am unable to select them. i can select them one by one easily.
Message 6 of 22
Pinned with Select Pinned Elements unchecked?
Message 7 of 22
Did you set the Design Option to active?
Can you show the bottom screen prior to selecting the lines?
Message 8 of 22
liMVT68
not pinned either. i have not had issues like this in the past.
Message 9 of 22
liMVT68
here is the screen shot of the bottom
Message 10 of 22
Are they in a workset that is not editable?
Message 11 of 22
liMVT68
just checked, the workset they are in are editable.
Message 12 of 22
Your Main Model is still active.  Change it to the actual Design Option you want to edit then see if it helps.
Message 13 of 22
liMVT68
just tried this again. still unable to select them via window selection. 😞
Message 14 of 22
They are not inside a group, are they?  Does that happen for everyone or just one person?  Maybe restart Revit.
Message 15 of 22
Lower your View Range Bottom Plane.
Message 16 of 22
liMVT68
everyone, unfortunately, but in another colleagues project, in 2022, it works, so I'm thinking it's some setting I have missed.
Message 17 of 22
Check the bottom of your primary view range.  It should be at or lower than the lines.
Message 18 of 22
liMVT68
that was it!! thank you!! apparently the view range was set up a couple of inches! thank you, everyone!
Message 19 of 22
Yep, that's exactly what I suggested above.
Message 20 of 22
liMVT68
sorry! I missed this response!! but yes, this was it!! 🙂 thank you!!
