Hi Community,
I converted an ifc model to Revit model and linked into a MEP model.
I manage to see the elements in the plan & 3D view, but when I make a section view I cannot able to see any elements.
Can someone help me fix this issue?
Gelöst! Gehe zur Lösung
Gelöst von Radish_G. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
check any view template assigned , try to set to none? or check setting of your section view line far clipping from properties. thanks
Hi Community,
File attached for your kind review.
I attached both IFC & the converted RVT file.
I tried and checked, when I created a new section line the section view will appear, but when you zoom to fit your view will disappear, which means you have an object or lines that far away from the main model. To check this you need to check your if linked and Revit file to delete those objects. Thanks
Hi @ennujozlagam,
It is because of the level line.
While I zoom fit I can able to see the entire view, but not the elements.
check out this please see attached and one more thing check your phasing and if you want to see the view activate your crop view/crop region visible/annotation crop. thanks
Revit has a 10 mile radius limit which you are exceeding.
So, what do you really want? Your issue is cannot see your section view? Did you open the section view?
Hi @barthbradley,
I get you,
but while I check the model (uncropped view)the max length of the element is 464 meters only.
Which means all the elements lie within the 16Km range.
Hi Guys,
I manage to spot the problem.
As you guys said earlier, its a phase problem.
I dod the following to fix that.
Thank you so much for your time and support.
@Radish_G wrote:Hi @barthbradley,
I get you,
Yes, you are right. I'm examining your file now. You are within the limits allowed -- albeit your Project Base Point seems to be an exorbitant distance from the Model. Currently, I'm having difficulties recreating your issue. So far, every cross-section I've made displays correctly. Are you sure that the section crop encompassed everything you wanted to see?
